Jeep Laptop Mount
Jeep Laptop Mount
Picked up a laptop mount from a company (not a sponsor, but easily searched on google). Mounted real easy, no drilling needed.
I use the computer to track myself real-time on Google Earth mainly. Connect a GPS device to the computer through USB, and Google Earth can track your coords in real-time using satellite imagery. If you don't have an internet connection, Earth will display whatever is saved in your cache. I make sure to preload the areas I'm visiting while connected to the internet, then later on I can see all the satellite detail!
Cascade Wanderer (07-02-2019)
Depending where you angle the laptop, it doesn't interfere with the passenger no. The way I have it in the picture would make it uncomfortable in that seat, but it's really adjustable.. height, angle, etc.. It also helps to have a small computer. The arm also comes out of the post in a snap, so you can remove it if need be.
There is a small amount of vibration, but it's actually pretty minimal. I'm surprised there isn't more.
It's actually a 10'' screen. The computer is an HP Mini 210.
