Intune i1000 DCX
Intune i1000 DCX
Just ordered my Diablo Intune i1000 DCX tuner for my 2011 JK. Gains up to 25 hp and has the economy gain of up to 4 mpg. Come pre-set with 5 tunes for stock, economy, 87 octane, 91 octane, and 93 octane. Will be shipped to my doorstep Friday and will be installed the second I get home. Will update yall once I have tested it out. So EXCITED
Hey bud...got mine today...Update when i get home - install tonight...I'll keep in touch also...
You sure about the HP upgrade...they changed there website very recently...I printed a
copy on Jan 31 ... Printed 1 yesterday different numbers...Just saying...
yeah - i mentioned this on the diablo forums - they had the wrong numbers up on the site. i was going to be furious if the intune had higher hp tunes than the trinity and cost less. but the tunes are exactly the same on both programmers. the lower numbers are the correct ones.
Update: City MPG: Before: 12 MPG After: 14-15 MPG
HWY MPG: Before: 12-13 MPG After: 16-17 MPG
This isnt even on the economy setting, i have it set to the 87 octane boost with throttle adjustment and tire adjustment. I love this product and would highly recommend it
does this allow you to adjust your TPMS? I don't like dash lights on and when I swapped my wheels and tires out I just used the Procal to turn down the sensor threshold.
I believe so, i haven't messed around with it too much. i know when your check engine light comes on you can scan it yourself and it will diagnose the problem for you. Other than that i have not touched the other stuff
