Installed Rubicon Shocks/Springs and Teraflex Leveling Kit....Wow!
I've been lurking on this forum for sometime and just got my first jeep a couple of months ago. I bought a 2007 JK "X" Red Rock crystal with 4.10's....Love It!
After allot of thought and study I purchased a set of new "take-off" Rubicon shocks and springs from a hard-top, tow packaged Unlimited. I also ordered a Teraflex leveling kit with "Quick Disconnects" after seeing the results on this forum.
This weekend I had the house to myself so I set about the install. I replaced my front springs which were 12/13 with 17's and the rear 55's with 58's. I also installed the shocks and leveling kit. Only took a few hours with a floor jack and stands. I gotta say....WOW! I love it...BIG difference in ride improvement and I gained allot of lift. The only adjustment I had to do after the install was recenter my steering wheel.....super easy thanks to the write ups on the forum.
After I installed the parts I got greedy and wanted more mods so I did some forum surfing and did the side marker light mod, flipped my rear-view mirror, drilled my side mirrors, painted my center caps, and put on my JK decals. I'm planning on upgrading tires and rock rails next. Thanks guys for the great info.
BEFORE:
AFTER:
BEFORE:
AFTER:
Man, that looks great! Fantastic improvement. I just put a bumper and winch on the front of my '10 and I think I'm going to order some 18's for the front. They're <$40 ea. I have a set of Unlimited-tow-Rubi takeoff shocks and springs in the garage but the fronts are only 15/16's so they won't be worth the effort.
I'm about to do the exact same thing as you...
TF leveling kit and JKU coils. I'll be going from the same stock springs as you to JKU springs (I think 18 front, can't remember rear). How much overall lift would you say you gained? I lost exactly 1/2" when I installed my OR-Fab stinger stubby, so I am ready to get some lift here. I will probably add 33"s at the end of the summer. Need to make room for them, but didn't want to screw around with drive shaft swap and all the other complexities of larger lifts, at least not yet. My wife and I just had our first kiddo, so money's a bit tight. This seemed like an economical way to gain a modest amount of lift.
Any problems with running stock bump stops and no brake line extensions? I expect not, but wanted to check.
Looks nice,
Jason
Looks nice,
Jason
Looks nice,
Jason
Looks nice,
Jason
The shocks are rear springs were free. I have $80 in the front springs (new from Wyckoff) and $55 in the spacers (used from a forum member).
I already had 0-2.5" JKS QD's. If not for that, longer front swaybar links would be req'd.
My total is $135.
My total is $135.
Let me know if you get death wobble with that setup.
I was running JKU springs + 3/4 daystar spacers for 6 months and all was great.
I then installed the TF leveling kit which brought my front up 2" instead of 3/4". I immediately started having Death Wobbles. I remove 1" spacer from the front and it seems to have fixed my Death wobbles.
Not sure what is going on but it definitely had something to do with the TF leveling kit.
