Installed my air tank today...
Sponsoring Vendor
Epic-Addictions Representative
Check it out! I bolted it down to a piece of plywood that was cut to fit perfectly underneath the carpet. I then used a razor blade to cut the carpet right around the feet. Check it out, let me know what you think.
![](http://farm4.static.flickr.com/3064/2747523157_f6d74ba444.jpg)
![](http://farm4.static.flickr.com/3058/2748356260_a173e85c02.jpg)
Sponsoring Vendor
Thanks! Tire inflation and an air horn I have. The wood is not mounted to the Jeep, but it doesn't move at all. I'm afraid to drill holes into the Jeep. I may end up getting rid of the wood and bolting it directly to the floor. Im pretty sure I can get to that spot under the jeep and use longer bolts.
Sponsoring Vendor
Sponsoring Vendor
