hydrogen cell teck.
hydrogen cell teck.
has anyone looked into putting a hydrogen system on there jk they say more hp and better mpgs but im a little liry about what it will do to the motor they say 25%-60% better mpgs but won't guarantee it.
you would have to run with too much hydrogen to get those totals, and you would have to retard your timing to almost top dead center. You MIGHT get 2-3mpg after tweeking it, but the O2 sensor will go squirley on you (you would have to have have the inlet after the sensor, and since hydrogen is lighter than Air you lose a lot of it anyway.
Too much O2 and your engine starts to run richer and gets more mpg.
Bottom line new vehicles don't cooperate well with these setups
Aside from running rich, and the problems that go with it there shouldn't be any other issues.
Just watch how you mix your reactor fluid (how much baking soda or caustic acid such as lye you use) it could draw a whole lot more amps then expected and this could go real bad real fast.
