Hutchinson Rock monsters on D60s
Does anyone have or know anyone that has Hutchinson Rock monsters wheels on D60 axels? If so, which model wheel?
I have found two that may fit, but I'm not sure
Hutchinson P/N WA-0568
Size 17 x 8.5”
Bolt pattern 8H – 170 mm BCD
Lug style M14 flange nut (hub piloted)
Hub bore diameter 4.93” (125.3 mm)
SAE rated load 2,900 lbs. - 60 psi
Backspacing 4.50” (114.3 mm)
Construction Cast aluminum alloy
Wheel assembly includes:
Assembly studs and locking nuts
O-ring seal
Hub cover
AND
Hutchinson P/N WA-0569
Size 17 x 8.5”
Bolt pattern 8H – 6.5” BCD
Lug style M14, 60° conical
Hub bore diameter 4.59” (116.7 mm)
O-ring seal
Hub cover
Size 17 x 8.5”
O-ring seal
Hub cover
AND
Size 17 x 8.5”
O-ring seal
Hub cover
One more wheel:
Hutchinson P/N WA-0566
Size 17 x 8.5”
Bolt pattern 5H – 5.5” BCD
Lug style 60° conical
Hub bore diameter 4.218” (107.1 mm)
SAE rated load 2,300 lbs. - 60 psi
backspacing 4.63” (117.6 mm)
construction Cast aluminum alloy
Each wheel assembly includes:
O-ring seal
Size 17 x 8.5”
O-ring seal
The one you have listed above - WA-0566 is made in 5 on 5.5 bolt pattern for cj's. Those should work. But it depends on the bolt pattern you get on your D60's
Atleast there are 2 people that agree that the CJ wheel should fit.
Thanks!
Yeah, I spoke with David @ Currie about this idea and we came to the conclusion that would be over kill considering the setup I'm looking foward to.
