How I ruined a pinion bearing by extending my diff's vent tube
#21
the only way you could insure that the crush sleeve doesn't get over crushed is if your pinion yoke were getting installed at the same time as gears/overhaul kit with new crush sleeve or, using the pains taking FSM method that requires the use of a high end inch lb. torque wrench - a vast majorty of mechanics don't do this and really, most of the time, it's okay not to.
Amen to that!
#22
Omg!!
I almost can't believe this!
I went out to the garage to fiddle around this morning and about fainted when I looked under the JK. The mess is all over the inner fender, wheel, tire, suspension, etc. Gear oil, pouring from the right side axle tube.
Can you say "d-e-f-l-a-t-i-n-g" boys and girls?
How about "d-i-s-h-e-a-r-t-e-n-i-n-g"?
I've had the Jeep back for one day since the overhaul kit was installed.
It would seem I was wrong about my vent line puking enough oil to grenade the pinion bearing. Obviously, it was something more insidious (like, my AXLE SEALS).
Now I'm stranded until I can limp this freagin' thing back to the shop on Monday morning.
Seriously bummed....
#24
JK-Forum Founder
awe man, that's gotta be frustrating. just to make sure, you weren't seen a leak like this before getting your pinion bearing fixed, right? i mean, if you were, it would have been really noticable, or, so i would think. so you know, in order to change out the pinon bearings, you need to pull apart your entire front end - more than likely, the axle seal was accidentally damaged when pulling things apart or being reinstalled. unfortunately, it happens and i seriously doubt that this is what lead to your inital problem.
#25
Woah, he doesnt use a in/lb torque wrench? I would have a serious issue with that myself. Back on the TJ days I blew my rear pinion yoke replaced it in y garage and since I didn't have an in/lb I took it to the dealer to have them check it. After the mechanic told me I got it in spec I told him I was thinking about getting a in/lb and which one does he use? Then to my surprise he gives me some BS about how he didnt have one but he could tell by feel. WTF? I felt like a cartoon character cause my face was red and steam prolly blew out my ears. I was told by an oldschooler back in the day to run like hell from any mechanic claiming to be a human torque wrench. I guess it stuck.
Goodluck getting it back on the road. Hate to see you broke down again.
#26
Eddie, I'm sure you're right now that I sit and think about it. The seal probably got damaged/dislodged when the axle shafts got shoved back in.
Miraculously, my local stealer has a pair of seals in stock, $22 apiece. At least I'll have parts in hand when I can get my Jeep back to my gear guy Monday.
