Home Made Rear Tub/Pinch Seam Covers
Old 03-08-2013, 11:36 PM
Dynamo's Avatar
Default Home Made Rear Tub/Pinch Seam Covers
I made these steel covers to hide the ugly visible tub and seam on the rear of my Jeep after I took the bumper off. The steel I used isn't really thick enough to provide good protection for the exposed corners, but if I make them out of thicker metal and powder coated them, they'd do an okay job I reckon. As it is, I'm considering these to be a prototype of sorts - a test fit - until I can get hold of the tools to make tougher versions. I gave them a few coats of primer and flat black outdoor metal/plastic paint. They're bolted straight to the seams. They do a good job of cleaning up the aesthetics of the rear end. If you can find a suitable type of black plastic of the sort the OEM bumpers are made out of, I think that'd work quite well too.
In the future, if I can find a piece of steel long enough, it'll probably look good with a single piece wrapped all the way around the rear. I drilled the holes already, so I could update it later on.
Before and after:
Closeups:
Old 03-09-2013, 02:39 AM
red2010rubi's Avatar
That look awesome.
Old 03-09-2013, 05:03 AM
GeckoTY's Avatar
Man that looks great!! I'm really diggin the look of having no bumper. Is there a company that sells those tow points to slide into the frame?
Old 03-09-2013, 07:40 AM
JLsJK's Avatar
Jeep looks great...those pieces really dress it up
Old 03-09-2013, 09:24 AM
k0260's Avatar
nice and clean looking. Good height too
Old 03-09-2013, 09:25 AM
XJtoJK's Avatar
Love this! I'm going to remove my rear bumper as well and this is a great solution to the unsightly lower tub, you should make a few more sets and sell em to me and others (to me for cheap...)
Jeep looks awesome!!
Old 03-09-2013, 09:31 AM
KY JK's Avatar
Off- Road Evolution makes them
EVO: Gussets/Brackets, EVO Mfg Rear Bolt On "D" Ring Mounts
Old 03-09-2013, 03:21 PM
Dynamo's Avatar
Yep, Offroad Evolution.
Old 03-09-2013, 03:24 PM
Dynamo's Avatar
Some people are happy to just paint the tub; which also looks great. I just wanted to try something a bit different.
Old 03-26-2013, 10:35 AM
Smith08jk's Avatar
Do you know what gauge steel you used?
Quick Reply: Home Made Rear Tub/Pinch Seam Covers
