high school build
Old 09-07-2012, 06:05 AM
  #371
e.davis3's Avatar
Originally Posted by Jeek.OlllllllO
My buddy did his. He cut like right where it drops off on the side
I was going to do mine but i will be getting my lift in a month or so and it will look funny with cut fenders and a lift and Rubicon tires
Thanks man. I'll have to try it out. Ill post pictures whenever it's done.
Thanks for your help.
Old 09-07-2012, 06:06 AM
  #372
bob-o's Avatar
Yea it's pretty easy if u use a dremel and cut off wheels. Just use painters tape on one fender to where u think it looks Good then measure everything so when u do the other side u know where to put the tape so both fenders match. Measure twice cut once
Old 09-07-2012, 06:09 AM
  #373
e.davis3's Avatar
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=363136"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=363137"/>
Dang! Your fenders look sick!
Makes me want to cut mine even more now!
Old 09-07-2012, 06:16 AM
  #374
bob-o's Avatar
Thanks a lot, all I did was cut the edge right before it starts to curve down. And measured 3" up from the corner and cut at about a 45 degree angle down towards the body. The front fenders were a little harder to do but I think I measured from the little circle in the center of the headlights to the edge of the fender 7" and cut there then measured 7" from the corner closest to the headlight to the outside edge and cut there. And if u get the door trim to put on after they are cut use some super glue also so the trim doesn't Peel off
Old 09-07-2012, 06:22 AM
  #375
bob-o's Avatar
I can take more pics later and post them up. Projectjk.com has a write up on there on how to do this. Check it out so u know where to cut the fender brace and I used 100% silicon to glue the front fenders to the fender brace so they don't flap in the wind while on the freeway
Old 09-07-2012, 07:06 AM
  #376
Rubitron27's Avatar
Yea trimmed my fenders. The dremel makes it easy.
Old 09-07-2012, 03:04 PM
  #377
e.davis3's Avatar
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=363154"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=363156"/>
Your jeep is sick. Info on mods and upgrades?
Old 09-07-2012, 08:37 PM
  #378
1978cj7jk2012's Avatar
Did mind with a box blade..
ID:	363420   Click image for larger version
ID:	363421   Click image for larger version
ID:	363422   Click image for larger version
Old 09-08-2012, 08:19 PM
  #379
MoreOvalteenPlz's Avatar
Got bored...
ID:	363739   Click image for larger version
Old 09-08-2012, 10:43 PM
  #380
Originally Posted by MoreOvalteenPlz
Got bored...
Hmmmmm...,, think it would be bad to paint my license plate black? I'm diggin the look..
Quick Reply: high school build
