high school build
#1691
Oh dang that bad huh lol worth it though lol how did you use the ratchet straps?
#1692
when you're doing installs like that on a regular basis you can never have enough c - clamps. little advise, most of these companies use the same 1/4 by 20 thread nutcerts. drill the holes to 3/8", on the ribbed part of the nutcert put a little bit of jb weld, then use a small tack hammer to put the nut cert in the hole. they will never spin on you again.
#1693
#1694
#1696
finally found some high school Jeepers on this forum! lol I'm a Junior in HS here is my rig
2012 JKU Rubi
6" Teraflex LCG Longarm lift
37x12.5" Goodyear MTR's
AEV Pintlers
Rugged Ridge snorkel
Bushwacker flares
Cobra CB
ORE C-Gusset Front Dana 44 Kit
Alloy USA Rear shafts
Warn front bumber
Bestop rear bumber
Smittybilt XRC 10,000lb winch
Warrior steel taillights
24" lightbar
2012 JKU Rubi
AEV Pintlers
Bushwacker flares
Cobra CB
Warn front bumber
Bestop rear bumber
24" lightbar
#1697
finally found some high school Jeepers on this forum! lol I'm a Junior in HS here is my rig 2012 JKU Rubi 6" Teraflex LCG Longarm lift 37x12.5" Goodyear MTR's AEV Pintlers<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=584941"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=584942"/> Rugged Ridge snorkel Bushwacker flares Cobra CB ORE C-Gusset Front Dana 44 Kit Alloy USA Rear shafts Warn front bumber Bestop rear bumber Smittybilt XRC 10,000lb winch Warrior steel taillights 24" lightbar
#1698
#1699
so i ordered the synergy cage, thatll be here in 2 weeks. along with my front a/r. so i'm thinking ill be between jobs for a week or two, should i back half the jeep frame, 3 link and outboarded shocks? i probably wouldn't 4 link the jeep until i have a job in a shop. i'm good with this stuff but there's a few more variables at play with something like that.
#1700
