HID Beam Pattern Shots
So I figured I would post up some beam pattern shots of my new HID lights.
First one is the road without any lighting on it:
This is with just the HID Headlights:
This is the HID Headlights AND HID foglights:
Finally HID headlights, foglights and windshield lights:
Same comment on the headlights..... The pictures don't seem to do the headlight beam much justice.
What reflector are you using?
Overall with all three sets lit up it looks pretty good!
Mikey
Mikey
I've had the same setup for about a year. The pattern is very good and the range of the light by far exceeds that of an oem headlight. The oem housings can still be pointed or adjusted as one desires. I've got a 4" lift and never moved the alignment of housings. I've only been flashed twice by other vehicles, and when I flash them back, well.....
Yeah the pictures really are decieving...I should have used the low-light setting on the camera. I will try to figure out how to work that tonight and post some better ones up.
They are actually SO MUCH better than stock.
Yeah I will also try to get the 20' wall shot for you.
