Hi-Lift rollbar mount
![Wink](https://www.jk-forum.com/forums/images/icons/icon12.gif)
For those of you that are interested I mounted my Hi-Lift jack to the rear roll bar. I will be putting up pics as soon as i get them developed (old school, I know). I fabricated two brackets and welded 3 1/2" long 1/2" grade 5 bolts into the; Then welded those to the rear roll bar. I also drilled a 3/16" hole in one of the bolts so i could lock it with a small pad lock. I secured the jack with wing nuts for easy removal. It looks very clean.
That's the best one I've seen yet. This is probably the way I'll do mine. Thanks for the idea. You should make this a write up and put it in the write up's section.![2 Thumbs](https://www.jk-forum.com/forums/images/smilies/2thumbsup.gif)
![beer](https://www.jk-forum.com/forums/images/smilies/beermug.gif)
