heres the Monster JK
BIGGER PICS UP
Vents:
1. Open the vents, turn the vent about 1/4 turn clockwise or counter-clockwise (depending on which vent).
2. This will unlock the vents and they will slide right out.
3. Use a small screwdriver to remove the vent bezel (lift four small "tabs")
4. Apply 3-4 thin coats of paint.
5. Dry, and you are done. Snap the bezels back in place and put the vents back in.
Bezel for speedo:
1. take off the panel from underneath the steering wheel
2. remove the two screws that become exposed(on left and right of steering wheel)
3. then, gently pull the hood/cover up and off
4. take out the two screw at the bottom of the gauges(left and right)
5. gently unsnap the clips for the clear plastic, set clear plastic piece aside
6. gently tug on the bezel and it should come right out
7. apply your paint and let sit
8. repeat the process in reverse and your all set
YOU DO NOT HAVE TO DISCONNECT YOUR SPEEDO TO DO THIS
it would say this was one of the easiest things to do
Bezel for speedo:
