hemi swap 6 speed info?
I am doing the aev conversion with a 5.7 hemi from a 2007 commander, I prefer to to stay with a 6 speed.
from what I've been finding I need a getrag 238 6 speed from a 2005-2008 dodge ram 1500 right?
my rubicon is already manual shift, would I need any other odd things other than the clutch and flywheel for a ram 1500?
even with the aev kit I should be fine with their computer/tune with a manual trans I would think
it will work with my stock rubicon transfer case right? bolts right on?
the one I found is a getrag 238 6 speed that fits:
DODGE 1500 PICKUP 05-06 M.T., 4x2; 3.7L and 4.7L
DODGE 1500 PICKUP 07-08 M.T., 4x2; (3.7L and 4.7L)
Patience man, the hemi guys sleep in or are out playin on Sunday's. Someone on here will chime in sooner or later. This is a better sec to get hemi answers than in the Modified sec.
Sponsoring Vendor
There are many versions of the Get Rag 238 the one you need is with rear rear furthest position shifter.
You can stay manual, but there are some changes you do need to make.
Gerry
Gerry
