HEMI Experience
HEMI Experience
Guys Im not much of an expert on this , so id like some info..
First what are the main and basic changes you need to do in the JK when you replace the JK engine with a 6.1 L?
Second does it have to be an automatic or can i have it as a manual
if yes, can the stock 6 speed handle the power?
Thanks alot guys
Thanks alot guys
and what are option as far as the manual goes
anything else besides the kit, engine and diffs?
i never thought id say this but i cant live without my 6-speed.
i guess im going to have to figure out some other engine, the 6.1 is out of the picture
Thanks alot for the info although im devistated
AEV working on a manual kit
Dan from Burnsville Offroad has done a manual with a 5.7.
AEV is working on a manual kit right now but I am not sure if it is for both the 5.7 and 6.1. . . . . . .
forum.aev-conversions.com
Go to the JK conversion section
If you go to the 6.1 auto then the only option for an auto is the 5-45RFE or you can wait as AEV is working on a auto tran’s conversion for the A580 which comes with the 6.1 SRT8 vehicles.
On AEV site they break out the expenses . . . . .
AEV kit $5,250 add $1k for coated exhaust system
Figure $7-8K for a 6.1 and auto trans $3K (can be cheaper or more $$)
Out of the Kit expenses approx $2K . . . listed on AEV site with part number and can be had for less on JK vendor sites
Manual to Auto conversion kit $1,200 . . . . .all told approx $18-20K in parts. I would bet you would not risk a salvage engine and tranny given your location.
You can put it all together cheaper but it will take some research and time.
The 5-45RFE trans is the only one available with the 6.1 for now and a few people have reported a flat spot with it . . .it prob is fine and has been pretty durable so far . . .the A580 will be more factory like as it is the intended trans with better gearing suited for the 6.1.
It really depends on your time table. I may go with the Ripp SC for now and wait to see what the manual options are later down the road and sell the blower . . given your location that is prob not an option for you.
If you are set on the manual . . . . the 5.7 really should be fine and if you are set on a 6.1 manual it should be an option before too long . . . .
Good Luck and don't give up on the hemi manual
DC
DC
