Harley Davidson Edition JK
An even better option would be to get the Harley Davidson LED headlights instead of the halogens.
(Black and chrome options available)
The work amazing in the Jeep. (Note these are the standard ones and not the HD branded version, but still identical lights)
For any headlights, even stock, you should install a headlight harness to bypass Jeeps pulse width modulation. But both lights can be operated with a simple H13 to H4 pigtail. With the LED there is a possibility you will notice a flickering effect due to the PWM.
OK... Like these better! Well done!
One question I have is are the lenses on any/all of these glass or plastic? I ask because the lenses on my JK OEM headlights have fogged over a bit on the inside. There is now way to polish it out due to the fact that I can't get inside them. There is no way I'm gonna toss a couple hundred bucks at another plastic lensed solution that can fog over too.
