Full Width
either a 44/60 or 60's front and rear......i read about someone making a bracket kit to weld on the full width axles of the buyers choice but cant remember where i read it at now.
Currie (FR & RR), Teraflex (RR),. River Raider is supposed to come out with complete kits FR & RR.
you'd need a D44 out of an F250. The currie brackets are made for 3 inch tubes.
here's something to try... you can buy the inner knuckles from Dynatrac that are made for their JK ProRock D44's (3" tubes). you can weld them to a D44 or D60 with 3" tubes to use the JK outter knuckles. Not sure if the U-joints are the same ???
I just finished up my ford 60. I modified the currie brackets but I'd never go with them again. half were bent out of shape, cut different etc.. I'd end up making my own from now on. The one question i'm running into now is since i'm using a full size 60 out of F350 I can't find a drag link that fits. I didn't order up the currie one yet cause I was told I could use the stock ford one and modify it. Well.... its about 6" to short to reach the hi steer arm. I am getting a custom drag link made up tomorrow. Other than that, everything went together as planned. I ditched the coil perches and went with coilovers instead to make it a little easier. Also ran a 3 link long arm from Rock krawler to free up some room on the drivers side. Now I just have to modify my exhaust to make room for the driveshaft and its all done.
pics plz
I've been wondering what ever happened to your build. you never updated your build thread. can we get some details? I've had a few ideas floating around:
1) Junk yard 60
2) dynatrac prorock D44 inner C's (beefy and made for a 3" tube) gusseted
3) stock jk outter knuckles w/32 spline hub (for sensors)
4) RCV axles with 35 spline inners and 32 spline outters
I estimate it to run about $4000 - $4500 on the high end.
about how much did your build run?
