Flexed-up Photos...Put em here!!!
#752
You can go ahead and get some Teraflex quick disconnects for around $100, that's what I have....you probably will rub a bit with the 33's and no lift on the front, but it shouldn't be too bad. Here's mine with disconnects and NO lift on 32's:
And the same spot with a 2.5" spacer lift and shock extensions:
And now with the 3.25" Rough Country and 33's....not at full droop here, but that's the best pic I have so far.
#753
#754
#756
Once you drive it disconnected you'll see why....the body will lean over pretty bad around turns and if you have to make any quick movements like if someone pulled out in front of you then it would not be the safest situation to be in. You can drive disconnected and it won't hurt anything, but it's always the "what if".
#757
And actually just a lift wont give me more of a flex will it? I have my eye on this
http://www.quadratec.com/products/16117_1003.htm
Its really all I can afford right now.
also I want the disconnects too
I just didnt know if it was a good thing that my tires are being lifted off and slamming into the ground.
#758
disconnecting lets the front suspension have way more flex...gives you more traction because it allows the tires to stay in contact with the ground longer. Here's some old pics of mine that i took to illustrate what I'm talking about.....
front connected
front disconnected
front connected (note the body lean)
same spot, front disconnected (body level)
front connected
front disconnected
#759
Rough Country 2.5" Budget Boost with shock extensions (you keep your current shocks)......
http://roughcountry.com/jeep_jk_2.html
Also, here's some cheaper disconnects that are similar to the Teraflex....
http://roughcountry.com/jeep_xtras_1146.html
#760
Sweet, So thats giving me a 2.5 inch lift without having to get new shocks!! Ive heard stories about people just putting spacers and not shocks and there tires come off. lol... But i wouldnt have to worry about that with this right? If not then thats what im getting. thanks man
