Flash Flood Jeep Run
#31
Sent from my PG86100 using Tapatalk
#32
Even though you are right about the serpentine belt throwing water at the stock intake box it is not enough to suck it in and damage the motor. Most motors that take in water bog down and turn off. If you continue to try to drive on it while you know something is up thats when you hydrolock your motor. Ive gone through many deeper puddles and never came close to hydrolocking with the stock airbox. Funny there wasnt even a splash of water in it? So I think that little snorkel design was a great design Jeep! As for hydrolocking a motor Ive almost had that done to several Cherokees. Basically all you have to do is pull the spark plugs and turn the engine over. Make sure to have someone hold a finger over each sparkplug hole to pressurize and rid all the water in each cylinder. Once you do that youre good to go. You might need to change your oil after that as well. Other than that if you take in water make sure to kill the engine!!! If not youll definitely do damage. I got all this from experience so trust me!
YMMV
#33
#35
#38
