First Look: 2010 Sport
Old 08-20-2009, 12:11 PM
JeepUserName's Avatar
I don't think the new top looks as good, but I'm curious how well it works and how easy it is to use.
Old 08-20-2009, 12:17 PM
HG07JKRubi's Avatar
did i miss something The soft top frame for 2010 has been redesigned ?
Old 08-20-2009, 03:04 PM
geoffcwilson's Avatar
The cable top is designed to be a lot easier to open and close. Instead of tucking in the top on the door headers, there is a spring-loaded cable that stretched down over a new door header rail that has more foam on it and the cable seals against the foam. No need to tuck in. It will certainly be easier but there is no way it can seal better.....
Old 08-20-2009, 03:06 PM
The hard top is "different" too - coming from new supplier.
Old 08-20-2009, 03:08 PM
Hellbound13's Avatar
So was this top redesign due to the leaks?
Old 08-20-2009, 03:36 PM
saltman's Avatar
Apparently not. I have read it bows out at speeds and leaks just as bad. I guess it just for ease of use. Time will tell.
Old 08-20-2009, 03:40 PM
Maybe the hard top was designed.
I don't see how this new design would fix any soft-top leaks.
Old 08-20-2009, 04:33 PM
Chukronos's Avatar
I looked at the pdf of the standard features. I see that both the sport snd Sahara will have 3.21 gears. So, the sahara will be worse than the 3.73 for the newbies. thought that was interesting.
Old 08-20-2009, 04:42 PM
Wow so they went down in gears? My 3:73 are bad as it is..
Old 08-20-2009, 05:07 PM
bigbluejk's Avatar
Who is the new supplier for the hardtop? Is it different?
Wow chrysler... you can now get the 32" bfg m/t on any model, but you have to spin them with 3.21s? wtf?
what about the auto?
Quick Reply: First Look: 2010 Sport
