Finally snorked....
#21
Took me about 4 hours. This was my first time doing anything like this and I went over things a few times. I did a test fit as well before even cutting to make sure the template lined up with the snorkel when it was bolted in. I also had to stop and change tools a few times cause I was going through my cutting discs on the dremel.
#25
#28
Other than that as far as work to be done under the hood its just removing the stock "snorkel" piece from the airbox and connecting the AEV one then sealing it all up.
The directions from AEV are really good and very straight forward.
#29
For anyone scared about cutting the hood don't be. You don't need to be exact. It is good to be but there is a metal trim piece that fills in the gap. If you cut a little off the mark the trim piece covers it.
I cut my hood with a Sawzall but I admit I had a beer before I started to reduce the worry.
I still haven't installed my trim piece because it was minus -15 when I did the install
#30
Attachment 306954
Attachment 306954
Then cut the hood, the trim ring gives you a decent amount of play in case your cut isnt as perfect as you'd like. It really isnt that bad to do at all.
