Finally! Pics of "Jack Ruby Poopmobile"!
Nice... one thing aside from painting the shovel (which won't last long if you use it) get some grab handles to help those boys. One question on the CB mount. How much vision out the window did it seem like you lost witht he CB? Not the camera just the CB. I love having a wide open view and have found the JK to be a little lacking and would be worried mounting my CB there would cause me to miss something. Not something trivial like traffic but something I go offroad to see.
As for the lift...I ponied up the money for the install rather than doing it myself. They said it was a pain when it came to the front driver's side as they had to cut a bolt to the manifold to get something in. (??)
I have Firefox too so I am not sure what the gig is with pics.
as for the CB install...as you can see it's a pretty thin unit. It doesn't obstruct anything at all. Even the rearview camera doesn't too much. I have it right next to the visor so it's fairly even with that. Have it so I can still use the visor too.
I believe they are 520's...85 watt. There are plenty of holes already! Looks like if I get the Powerplant winch, I';; have to move them out. Still contemplating that. Quite a bit of $$.
I know they paint D rings red for ads and things, so my idea is to paint the D rings Rescue Green. Also, mount one of the pins going the other direction so they are facing each other. Use the leftover green paint for the shovel.
That, and give me your bumper and lift. Ok, I'm out of suggestions, great rig.
New mods...new pics!
This weekend I finished up what looks to be close to my last mod. That's what I have told my wife anyway. Last thing to do was put on my Warn rear bumper and tire carrier. I kid you not, easily weighs over 300 lbs.! Funny how right next to the Jeep I am working on Lotus #2 getting it prepped for the track and I am doing anything possible to lighten it up!
I decided to cut the metal rod off the weld
nuts and just use my 7 year old "monkey's"
hand to insert the washers and nuts!
Still have to trim so I have no gap with
the flaps. I really like having them though.
After the bumper installation, they give
instructions to cut the 3rd brake light and
put it over the top of the spare...huh??
I am actually thinking of placing the 3rd brake
light below the spare where people can see
it. I have the rear view camera attached to the
bottom of the swinging carrier. Can't see a damn
thing out the back without it!
I was going to do it myself as a buddy of mine just did one. I opted for Central 4WD to do it so if there are issues, I could fault them rather than myself.:toung: I got away with a quote of $350. Took them 2 full days to do it. They wanted to charge at least 5 hours ($500) and I refused. Not my damn fault they don't have a lift! Honestly, $500 might be a little high. They said they wouldn't do another JK for less than $750. I can't help the learning curve...they should know more than I anyway! I was annoyed to find when I put Jack of the lift, the driver's rear brake cable was tightly rubbing against the tire! I figure to put in on yourself you could do it in 8-10 hours. The Jeep is difficult to get used to with the lift. Rather than being "tight" like the stock set up...it's very loose. Took it in for an alignment and they said it was spot on. Was told the only thing needed to do after putting the lift on was to straighten the steering wheel as nothing else changes! I was under the impression from reading the forum that it made a difference. The guys at Les Schwab tire said "nope".:toung: I'll get used to the feeling but it's squirrely.
