finally got my tires mounted.
Couldnt take the pizza cutter look anymore. Now if my tinted window kit would have been the right color I would be set. Might still do 2 inch lift once the discos go on and see if it hits anywhere.
As far as fitting 15's I will crawl under tom. and see what kind of brake clearance there is. The backspacing is 5" and I think its perfect. Doesnt rub at full turn. The center caps are only off because I was goin to paint them black but not sure if I will even put them on now. Maybe when the lift goes on.
have you played in the snow yet? i need to figure out what tires to but, so how are thoes in the snow and on ice? thanx
