Finally Got the lift on Skyjacker 2" Rear+ OME Front Springs
The original install had the Skyjacker 2" spacer lift. I have the tow package on the Jeep and after the install the rake was very noticeable. Pre lift was almost 1.5" Difference and the spacers were true 2" so no change in the rake only more noticeable once the Jeep was raised. To fix the rake and bring it back more level I added the Old Man Emu 2" HD spring and no spacer. The HD spring is more than 2" and it brought the Jeep to almost level. It is only lower by .25" front to back now which I think is just about right. I will be adding the Shrockworks bumper soon so worst case is I can always add a small spacer on top of the spring if needed.
On road ride is great. Hope to get to RC soon to see how it works off road.
Also added 1.25" Teraflex wheel spacers.
What do you think?
Pre Lift Driver Side:
Lifted Driver Side:
Pre Lift Passenger side:
Lifted Passenger side:
Rear lifted:
What do you think?
Lifted Driver Side:
Rear lifted:
