Finally, AEV Hood Install
Hood is a very easy install, very easy. The fit was right on with the AEV Hood, did'nt need to make any adjustments at all.
Just unbolt your stock hood: First disconnect the ground strap over by the batterey, next un-plug your hose for the winsheild cleaner, then take off your front latch and spring.
Close hood: you will need a #45 Torx bite to re-move the bolts from the hood hinges. after takeing off the bolts for the hinge, just lift the hood off.
To install new AEV Hood just reverse steps........
Awesome, hopefully I can get the guy who's painting it to give me a hand real quick and get it on there. Sounds like it's a 10-15 min project.
