Fender flares? Which ones to buy
#31
I love my Poison Spyder crusher flares. Got the aluminum ones. They are rock solid!
Attachment 334240Attachment 334243Attachment 334244Attachment 334245Attachment 334246
#32
Originally Posted by pasteris71
Has anybody cut their fenders and left the inside fender well on while doing do? I have seen it done both ways now and I am thinking of just leaving the insides on while cutting.
Also after I cut the fenders on my jk I spent a good amount of time with a sanding block getting the edges perfect then I put on some black door trim and shrunk it with a hairdryer for a really tight fit...i have seen some really good looking fender chops and ive seen some real hack jobs...patience and planning are key..so make sure you take your time and have an extra set of hands on standby...good luck and post pcs!
#34
yup, i agree but i haven't heard anything bad about them? just wanted to know what you heard.
#36
i have 2 say that i really like the flat fender look but even though that posted video looks impressive if you slide into any flat fender out there including the plastic ones you can pretty much kiss your sheet metal good bye..if you get up close and personal with any rocks or trees on a regular basis i would say just cut the oem ones as they were designed to break away on impact...if not and you are just going for clearance then those psc flares look pretty sweet
#37
Need some help.
I really like the massive bush pocket flare fenders. The only issue is I have an AEV Snorkel that runs along the top of my passenger side fender. Will the pocket flare work? has anyone attempted this?
