EVO Rear RockSkins and Tire Carrier Install
Old 04-10-2014, 08:56 AM
  #331
Jeek.OlllllllO's Avatar
Originally Posted by Biggy
You should really install it first and then remove and send it out for powder coat. The skins take a lot of massaging to get them to fit right trust me and you might damage your finish. Evo recommends doing it this way in their instructions as well.
What the there was instructions? wtf I didn't get them!!!
And yes they are pretty hard to install it makes it easier to install the corners with the too offf!
ID:	544657   Click image for larger version
Old 04-11-2014, 12:22 PM
  #332
jeepmedic308's Avatar
Does anyone have a really good break down of how to wire up the lights for us that aren't too savy with this
Old 04-12-2014, 08:49 AM
  #333
Ok so for the most part everything is finished however there are a couple of issues im having. Two of the nutserts popped loose as i was drilling into them. Now the screw just spins with the nutsert as i try and tighten it or loosen it. Is there any way to get the screw out? I can only get to the back of one of the nutserts but the other is by the rear door. Next i used a 4.5" wholesaw to cut my lights but the passenger tailight wont go in all the way. Is there an easy way to get it to fit? I have already made sure to push the metal piece behind it all the way back. Also whats the trick on getting the tire carrier to swing in and out easier? Right now it barely opens and is a real pita to close. I know that you can thread the joint in or out but its still reallllllly tight to the point where its scraping off the powder coat when i close it. Again all of the advice is appreciated
Old 04-14-2014, 10:48 AM
  #334
All finished!
Old 04-16-2014, 05:19 AM
  #335
bob-o's Avatar
Love this carrier!
Old 07-15-2014, 01:20 PM
  #336
Sponsoring Vendor
Off Road Evolution Rep
serveapurpose's Avatar
Give us a call and we can help you out.
Old 07-15-2014, 01:25 PM
  #337
Pinzguy's Avatar
Does anyone have pics of the gap with a size reference
Thanks
Brady
KCCO!
  #338
JE8154's Avatar
Yea, if he's still installing this 3 months later.
Old 07-16-2014, 12:36 PM
  #339
I was able to figure it out..thanks!
Old 09-22-2014, 03:28 PM
  #340
I just ordered the rear rock skins, will have to wait about a month or so to get the tire carrier....(i needed 2 new tires). For taillights, i found a set of 7led 4" lights on ebay for $60.
1 of the led's is white for a reverse light.
I also got the poison spyder led resistor kit after seeing some of the earlier posts.
How much work is needed to get the rock skins to fit halfway decent? will i need body tools, or would a simple hammer, clamps, and ratchet straps work?
Quick Reply: EVO Rear RockSkins and Tire Carrier Install
