Evo Front Coilover Rubbing...
Ya that is what I say... EVO has a declaimer about:
"Note: *Front Aftermarket CV Driveline is required for proper installation and is not included with kit. *EVO 14" Travel Front Coilover System on Manual Transmisson JK's requires exhaust modification.
But nothing what so ever on backspacing issues. That is the way I feel, I spent all that money, and chopped up my JK for something that has issues that were never mentioned. Update: Still no call back from EVO....
Sponsoring Vendor
Just seeing if anyone with the EVO front coil-over set up installed has had or is having rubbing issues?
I just got my kit installed this past weekend and it is now rubbing when I am at full turn in either directions and have the side up on a rock or anything higher then 6". The higher up it goes the worse it gets. I attempted to adjust my upper and lower control arms to see what would help. Seems the shorter I make the uppers the better it gets (More caster, but my pinion angle goes down=driveline binding/vibe). I talked to ORE and am waiting back for a reply from them.
I have 35"12.50 with 4.25 backspacing on 17x8 wheels.
Just seeing if anyone is having this issue.
Is your axle centered at ride height?
Do you have any trackbar relocation brackets?
We have not really seen this except for vehicles with larger backspacing wheels.
Simple fixs:
1) Wheel spacers
2) Small adjustment on steering stops.
3) Smaller backspacing wheel (recommended)
Usually the phone is the best way to get ahold of someone when you would like to talk to them.
Give us a call anytime Monday - Friday 8am - 5pm PST
714-870-5515
Sorry for not getting back to you asap.
Simple fixs:
1) Wheel spacers
714-870-5515
Simple fixs:
1) Wheel spacers
714-870-5515
I did call, left a message, and sent 2 e-mails. But yes you did call me back after that post....
Can I see a picture of the setups with 3.75" backspacing or less, preferrably with stock fenders? The next setup I'm lookin at would put me there and I'm curious to how far it'll be stickin out. Thanks
JK-Forum Founder
not 100% sure but, on my front drive shaft was making contact with the exhaust cross over at a full droop. we installed limiting straps to prevent any problems but, if the exhaust were rerouted, i would imagine limiting straps wouldn't be needed.
X2 - also, we relocated my crossover (limited options) and I still have to run with limiting straps.
i also think you would need to reroute the crossover. as the drive shaft can hit the exhaust crossover.
Randy, have Gerry and Adam re-route your crossover to behind the cross member like they did on mine. I have no rubbing issues at full droop and no limiting straps.
