EVO Front Coilover Bolt on Kit????
Is anyone on here running EVOs front bolt on Coilover system. I am very interested in running it. I can weld the weld on kit but I would rather go with the bolt on kit at this point. If anyone has any info on it please let me know. Thank You...
Last week i ordered the Alpha 1 from Outlaw offroad.It should be here this week.I really like than i don't have to cut the factory buckets off. Just in case the elusive diesel ever materializes.I can just take them off and move them.
Well for one I hate drilling holes, two some of the holes were really hard to get to and drill, and three I could have welded on the brackets twice as fast as it took to bolt it up. Thats just me. I'm redoing my coilover mounts with some custom ones that will mount on top of the axle instead of behind and also have a slight rake in them. just my .02
I'm not positive, but I think you still have to cut out the stock suspension with the evo bolt on kit. That really is what takes the time. The weld on wasn't that bad to do, just took some time to cut and grind the stock stuff off. The EVO mounts are pretty straight forward as to where you need to put them for welding. ORE says that they don't sell many of the bolt on kits. I haven't done much of this kind of work on my vehicles in the past, but it wasn't that hard to do myself.
If you can weld, go with the weld in kit.
