EVO 12" Front coilovers, Teraflex LA kit, Teraflex high steer kit & Teraflex 4" coils
#53
#54
#55
#56
I don't remember what the degrees were, but the front pinion is pointed slightly below the TC output. The rear is pointed right at the TC output. I have zero vibes, and I've taken it up to 85mph.
#57
My caster is at 4.7 driver 4.4 passenger. Front pinion angle doesn't look too steep. I guess I'll figure it out eventually.
Thanks for the info
#58
I have a mild hum at 50mph which get a little louder around 65mph. I noticed this after my first trial ride with this setup. Might be the tires
Thanks for the info
Thanks for the info
#59
They are the same length eye to eye both the uppers and the lowers. I can't explain it. It wasn't humming after I drove out of the alignment shop. It started this past sunday.
#60
Make sure you put a wrench on your suspension components to ensure they are still torqued to spec. Also what he said, make sure your caster is equal on both sides. Good luck.
