easiest welding style?
just wondering what the easiest welding style is i want to learn how to weld maybe over next summer or something
the local welder is 65$ hour and i got ideas man
also what about plasme cutters can the y cut off ur fingers
tthe way i understand it is in order for it to work it heats the metal and it cuts it with the plasma produced from that or something like that
what is mig welding
is that liek a flame welder or do u use rods i understand what welding is
but then again i thought they use to use welders to brais fish so...
hope fully my parents will get me a class next summmer
my dad wants to learn to
Welding 101
It all depends on how much experience you have. Mig is probably the easiest to learn if you just want to "stick" metal together. Not really to worried about "full Penetration"(yes I said Penetration). Not saying you can't get it with mig because you can..... Bla bla. I'm getting off topic!! A.D.D. lol
M.I.G = Metal inert Gas. The short and skinny is you have a whip and wire comes straight out the middle of it with a shielding gas around it to help protect the weld that you are producing. I'm guessing that you would be welding steel. Thats a whole lot easier to start with.
Anybody can mig weld..... only some can do it right.
I'm sure other people will chime in with more info.
Just a quick note i've been welding for about 7-8 years all aspectsof welding. Mig, Tig, Stick, and flux core and also all positions flat, horizontal, vertical and overhead. I'm on my advanced welding right now Armor Plate. Now thats a whole new can worms!! LOL
Hope this helps a little
Forgot to mention Plasma cutters. like someone said the plasma burns your fingers....... it's the high pressure air that blows away the charred skin and bones!!!LOLOL
3 things:
1) here's some excellent resources, not that I'm a huge Miller fanboy: http://www.millerwelds.com/resources...g-your-skills/
2) MIG (GMAW) is the easiest
3) Plasma cuts via errosion. The torch works by super heating / ionizing air into a plasma stream and superheating the material under the tip and literally blows the material away. Catch, the material has to carry current. It'll cut aluminum and stainless which normal flame cutting won't.
3 things:
one of me frineds all ready knows how to weld
he does a lot of set build ing for his school
he did one of those spiral stair cases with a little help
