Door handel mod Bad Ass
maybe the .01 of a lb you saved from the holes save you some gas mileage? but the drag from the airflow might cost you that weight because it could get caught in a vortex ring state around the sphere behind the handle...
Ok so first I found the center line in the center duh. There is a small line from the molding process.
Then I went over 1 inch X 4 on center and made a little mark.
I used 7/16 bit but you can use whatever. I would not go higher than 1/2. I used a bit for steel as in makes a sharper cut.
I put a J-box cover wrapped in electrical tape as I'm an electrition and thats what I had around (electrical tape) as not to scratch your jeep. It was 4X4 by 16th in thick
Take your time and go slow.
Trim off the burs with a razor blade.
Then BAM your just like me.
The End.
Ps. if you have a hummer do NOT use the 4X4 plate behind the Handel.
The End.
going from left to right your second hole is higher than your others... im just saying but it looks okay i guess if you like things like that...
