Do I really need D60s?
#41
Well here's the thing. The curb weight of an Unlimited Rubicon is 4340lbs with an AT trans (slightly less with a manual). The GVWR is 5465lbs. When you exceed what the vehicle was designed for, you cannot complain that the vehicle isnt doing what you want. I do think the front axle is undersized, and that the rubicon should have a real D44 up front, not the D30/44 hybrid. But for what it was designed for, the rear D44 is fine. If you surpass that design, then its your job to upgrade it.
#42
I recall a 74 F250 4x4 PU I bought new. It had a Dana 44 under it and there was/is no comparison to the lightweight POS we have under the front of ours.
It wouldn't have been that hard or costly to do it right. The incremantal cost to spec out a 3" 3/8" front tube would have been minimal.
#43
Oh agree, ultimately Chrysler cheaped out. Especially on the front axle. There is nothing heavy duty about the front D44 in a JK. The front D44 in my J10 is leaps and bounds stronger. But ohwell, nothing else chrysler does is high quality on the JK, why should we expect the most important parts to be high quality? :(
#44
#45
Ok so I'm running stock X axles with 37s and wheeled it pretty hard. I've only broke 1 u joint. I'm now going to 40s and know my stock won't hold up long. I have been thinking to do a front D60 and then beefin up the rear 44 just to save a little money. I have been reading that the width of the D60s are different. What are some other problems I could run into going that route? Thanks
#46
#47
Most companies have them drilled in the back for a dual bolt pattern, but up front the 5x5.5 is usually needed to have room for the locking hubs. I know that Currie has mentioned that they can build them with a 5x5 bolt pattern, and drive flanges, but you lose the Kingpin of the Dana 60, and all of the strength of the outer 60 and reuse the stock JK parts.
