diesel engine ??
well after a lot of reading, research and calling around for advice and trying to find a shop that would help with the work it looks like i will be waiting with the masses till the diesel comes our way !
i was hopping for a quick and semi painless swap but after really looking into it i dont think i have the time or money to spend trying to do this.
so for now i
so for now i
Originally Posted by POTO
CRD logo on the back door and that got me to thinking. Found out they're no longer made by Dodge and are now made by Freightliner. They have a BlueTEC SCR Diesel engine with AdBlue. It's a 3.0L V6, with 188 hp and 325 ft.-lbs. torque from 1,400-2,400 rpm. I know your giving up ponies but your increasing torque, plus you get the MGP's. Got me to thinking if this is a viable option, especially if they come out with a tuner for it.
BTW with the thoughts of Jeep mods in the head, I ended up having a pleasant drive into work.
It would probably cost a more than few thousand dollors to this swap and make everthing function properly and with the price of diesel being more that gas, i don't really see you saving any money at the pump.
Of course, you're dealing with a nightmare getting it to pass emissions. If you don't have to deal with Big Brother, though, you can take all of that HP robbing garbage off in the swap and retune it. Win-win (except for the dirty tree-hugging hippies).
so what exactly is adblue? And for diesels... Torque is mostly what matters, hp not so much... 325 is doing better than the 4 bt (stock) and about half of what the new diesels are supposed to put out. I wonder how difficult it would be to get a tranny and transfer case for it. As long as it's not bigger than the hemi (almost impossible) it should be a feasible swap...?
From what I recall the Sprinter is and had always been made by Mercedes. When they first started showing up was when Freightliner aquired their large truck division or some type of strange contract was made up to allow them be sold with Freightliner badging (which makes since, because there hasn't been a Mercedes over-the-road truck dealer in the us for many years).
During the time Mercedes had the reins of Chrysler they rebadged the Sprinter and put the Ram name on them.
OK, I'm still new here and a little nervous about sharing due to vast knowledge that I have seen on this forum, but diesel is a topic near and dear to me so here goes.
A friend swapped a cummins 3.3 into '97. the 3.3 is a little smaller, but quieter than the 4BT and can be purchased in a common rail version (so it can be computer tuned). He has seen some pretty good MPG numbers (over 30?) - even with 37" tires. power was not a problem, either - absolutely NO winching in Moab, INCLUDING prichet (but he is also an excellent driver)
Please note in states like California where emissions are a problem this is not an option. However, in Ohio its still viable. Even more viable if you run Bio, like I do. I don't want to share details, but it bolts up to a manual transmission from the 6cyl AMC motor (2006 and prior).
Anyways, I purchased a 2008 4DR X this week and will be swapping in a 3.3 in the future. (Hopefully my winter project!) When I do, I will definitely share.
My biggest concern is figuring out the electronics - yuck!
It is not particulates that is the main problem here, it is NOx. The way you address that is threefold; you alter fueling and timing to lower peak cylinder pressures and temperatures at the expense of lost power. You aggressively recirculate exhaust gases, and you after-treat the exhaust with Urea compounds. To keep the engines performance levels, you are then forced to bump up displacement and that with the altered timing results in a motor with fuel economy only marginally better than a gas engine. This is what is killing the performance of diesel pickup trucks along with the ultra low sulfur diesel fuel required being priced higher in most states than gas. The particulate filters are also a contributing factor to lessening the diesels previous performance and economy benefits. The purge cycles needed to clean the filters cost 3-4 mpgs.
