Did the locker mod (pic & vid)
Hey guys,
I'm a noob ont his board andmyname it's Diego.
Just wanted to share that I kinda followed the write up over JKforums about the mod for the lcokers, but the main differene it's that we didn't use any fancy iluminated rocker switch or any aux led to let us know once the locker it's activated. Instead we used the stock "locks" symbols of the cluster.
In the manual mode, of corse it operate like the ARB units, whenever you want, at any speed and at any transfer case postion.
The stock mode still works as was builded, but it doesn't flash anymore the "locks" symbols in the cluster but they iluminate as well and lock the axles in 4Lo mode and above of the speed limit, if not they dissengage like the stock system.
Works pretty good.
Also we added a switch in the empty buttom panels dissabling the ESP/ABS-BAS and Airbags at the touch of one buttom. The stock system as well work the same way as factory.
Here is a little vid I took it's 10MB , Right Click , Save Target Ass...
Click Here
Later,
-Diego
Works pretty good.
Click Here
Later,
-Diego
-Diego
I used simple switches but stock cluster lights wich is different from all those that did this mod I cannot make it work the way we want with stock buttoms because it's controleld by a chip card behind the buttom, it's a special signal that takes the EC to lock the diffs, that's why you need separate switches.
-Diego
-Diego
https://www.jk-forum.com/forums/jk-write-ups-39/bofer84s-locker-mod-write-up-11941/
Hey guys,
Works pretty good.
Click Here
Later,
-Diego
Works pretty good.
Click Here
Later,
-Diego
can you please repost the link and the pic? they do not work and would like to see your write up.
thanks
