Daystar 1.75" Lift w/33's - Picture
#31
posted the photos of the install on another thread: https://www.jk-forum.com/forums/modified-jk-tech-2/wheels-spacer-questions-3899/
here's a side shot of my jeep w/o a lift (not a great photo though, lots of shadows):
I just put the spacers on Tues. I'm going to retighten them tonight.
I'll try to post pics too.
I was rubbing really bad on the sway bar without them. Now, I clear the sway, but rub a little on the air dam.
I'm sitting on some front end 3/4 spacers, but after reading this thread I'm going to go w/ the this so I can lift the rear 3/4 as well.
Now, I need to decide if I want to stack my front spacers or sell a set. huskynox, your ride looks nice.
#32
How hard was it to install? So you are saying if i install this 1.75" lift on my new rubi with the standard tires that i would also have to install wheel spacers?
#33
You would only need wheel spacers if you are going to change your tire size to a larger/wider tire. If you keep your stock wheels, you wouldn't need a wheel spacer.
#34
Hope that helps!
#35
What is included in your 1.75" lift. My 3" lift had new longer rear sway bars that did rub the rim of my stock tires. I just moved them to the inside though and that seemed to work. Once I got new wheels I moved them back. There might be mention of that in wayoflifes lift write up, possibly even a picture. Yours would be shorter if you have them so you probably wont be affected.
Yah, it's mentioned at the end of the write-up.
#36
Here's a picture of the Pro-Comp or Daystar (same kit) kit. It comes with 4 1.75" spacers, 2 longer Front Bump Stops, and 2 Rear Sway Bar lowering brackets. It doesn't come with Rear Bump Stop extenders, which I found weird, so I made my own. I called Daystar and they told me Rear Bump Stop Extenders weren't necessary with a 1.75" lift....? I wanted to be safe, so I built some out of 1.25" 6063-T52 aluminum extrusion.
#37
The only other thing I did was add a lock washer behind the steering stop stud to prevent rubbing while 4-wheelin'. There was no rubbing with the 1.75" lift around town, but I was concerned with rubbing while 4-wheelin'. With the washer in place I didn't notice any steering limitations and there was absolutely NO rubbing.
#38
https://www.jk-forum.com/forums/stock-jk-tech-12/how-do-i-adjust-steering-stops-3608/
#39
Tev,
It's a very simple instl. Just study the Teraflex Instructions for their 2.50" buget boost, they're on-line. They have some pretty good pictures.
Wayoflife posted a picture of the TJ steering stop stud, it's the same on the JK. Just add a standard lock washer under the stud. It should take you 2 minutes a side to instl.
Again, the kit is simple. You can get the Pro-Comp Kit off of Ebay for $98.
The front was a little simpler than the rear because I didn't have to disconnect the Track Bar. I did on the rear. I did the whole front setup in less than 1 hour. The rear took about 2 hours because I had to disconnect more stuff.. ie. Brake Lines, Emergency Brake Cables, Track Bar, plus it was the first end I did so I was being extra careful.
husky~
husky~
#40
Tev,
husky~
husky~
