Daystar 1.75" Lift w/33's - Picture
#21
#22
#24
Yep, we already thought of that and took a look. There is room for a 34", but that would be the limit.
Also, you'd have to run wheel spacers if you ran the stock wheels.
Husky~
Husky~
#27
33's
Do you think you could run the 33's without the spacer lift kit? I have heard a 285 70 17 will fit no prob and have seen a few pics to prove it. Any thoughts? Are your 33's 285s or 305s? Your input is greatly appreciated!
Dave
Dave
#28
I'm running BFG ATs 285/70/17s on mine w/o a lift, but opted to get 1.5" wheel spacers to get rid of the front tires rubbing at full turn.
#29
guns2323,
I'm running 285/70-17's. BFG doesn't make a 305 MT. You will rub the sway bar at full turn without the lift. You can add a washer under the steering stop stud and be fine though. I added a washer myself to stop rubbing at full articulation.....with the sweep of the tire through full suspension travel the tire would have rubbed the sway bar at full turn.
I'm still debating on running a 1.25" spacer for a wider stance.....
FzyPchz,
Do you have a picture posted of your Jeep with the spacers and no lift?
FzyPchz,
#30
here's a side shot of my jeep w/o a lift (not a great photo though, lots of shadows):
