Day Star Hood Vents Switched Around
I wasn't a big fan of how the hood vents looked in all the pictures on the internet but I liked the shape and look of the hood vents. I purchased the vents and changed the way the vents were placed on the hood. I basically switched the vents from one side to the other. Anyway just thought someone else may want to see pictures of the hood vents switched around.
Hi!
Thanks a lot for sharing because I was having the same hesitation before I saw what you've done, it looks awesome that way!
Question, how did you manage with the template, how did you adapt it?
Phil
Phil
Here is a couple pictures of the vents placement on the hood with a tape measure for anyone interested in the layout of my hood. I cut the vents out of the original template and taped them back into to a position that I liked. Be sure to leave some room around your cutout vents so you can tape the vents in the new location on the template. I used the holes already on the template as a guide to align the cutout vents.
Inside edge of vent - 18 inches
![Click image for larger version
ID: 583341](https://www.jk-forum.com/forums/attachment.php?attachmentid=583341&thumb=1&d=1513723586)
Lower outside edge of vent - 32 inches
ID: 583343](https://www.jk-forum.com/forums/attachment.php?attachmentid=583343&thumb=1&d=1513723586)
Upper outside edge of vent - 34.5 inches
ID: 583342](https://www.jk-forum.com/forums/attachment.php?attachmentid=583342&thumb=1&d=1513723586)
From window bump stop hole to screw hole vent (drivers side) - 3.5 inches
ID: 583344](https://www.jk-forum.com/forums/attachment.php?attachmentid=583344&thumb=1&d=1513723586)
closest screw holes from underneath - 19.5 inches
ID: 583347](https://www.jk-forum.com/forums/attachment.php?attachmentid=583347&thumb=1&d=1513723586)
Hope this helps anyone interested.
