Dana 60 swap
Dana 60 swap
Forgive me if this question has been asked before and if it is a stupid set of questions but here we go. I am looking at a possible axle swap for my rig and have little to no idea where to start. Unfortunately I am not in a spot to buy a pro-rock 44 or 60 so I am considering building one a little at a time as money provides.
Question #1) I know that you can have a 30 in front and a 44 in rear or a 44 up front and a 60 in rear, but can I run a 60 up front and a 44 in rear?
Question #2) Is there anything I should be looking out for in buying a dana 60 axle to rebuild?
Thanks
Thanks
Thanks
Thanks
RedX......if you don't mind my asking, did you get a tone ring to work or are you going with-out TPMS and ESP/BAS. if so, how did you do a go-around. Also is that an electric or manual locking hub. thanks Mike
Thanks
Thanks
and it was alot cheaper
They are mile marker manual hubs. I ordered the tone rings from dynatrac, so I should have everything working in the next couple weeks. It drives and shifts fine without the tone rings, you just don't have a speedo and the lights are on.
