Dana 60 builds
i still have all my stock parts, i just need to figure out how to install them on the new axles. mabey they need to be machined to fit or add brackets or tabs.
i will look into this more at the end of the build.
give solid a call. all you have to do to keep your electronics is use the tone rings. you dont need to make your own dash or anything. we have nothing really in common with TJ's. We get our speedo signal from the trans.
If that were true then when you Re-Gear the speedo would not change since it would always detect axle speed. Changing of Tire diameter would still affect it though.
I'm pretty sure people on here who have re-geared also had to reprogram the ECU to get the speedo accurate again.
Also lookup the guy's who have installed an Atlas, I'm pretty sure they were having speedo issues since it's in the TC.
