Da Sha Vu 5.7L VVT @ SLC
Old 08-24-2010, 05:30 AM
Sponsoring Vendor
Screamin Lizard Customs's Avatar
Originally Posted by brent_f70
Are you guys actually getting the VVT to kick in and work? I figured with our brick inspired aerodynamics the VVT would never really cut off cylinders. Not that any of us put in the Hemi for fuel milage but is the VVT getting better mileage than a standard 5.7 in the JK? Got any real numbers?
The VVT does not cut off the cylinders (that's MDS), the VVT will shift over the cam to open the valves to give the motor more horsepower
AND, Yes you can fill it shift over it's a little kick in the pants
As far as fuel #'s...it is better than the old 5.7 and 6.1 but every Jeep is different because of weight; gears; size of tires, however the last JK was a Rubi and when it was dropped off it was getting 14.8 and after the 5.7 VVT was put in during the test stage it went up to 14.9. Around town testing was getting 13.2 to 14.
All in All you do get the better fuel economy and when you need or want it you get the power very close to the 6.1
I almost forgot, the 6.1L cost a little more and needs synthetic 0W-40 oil and the 5.7L just needs 5W-20
Old 08-24-2010, 05:39 AM
ARinmyJK's Avatar
Exclamation
I'm sitting here in your lobby and didn't get to see the hemi swap? Wait till you get off the phone...
Old 08-24-2010, 06:29 AM
Sponsoring Vendor
So what did you think
Old 08-24-2010, 06:33 AM
rws
rws's Avatar
Ever toy with the idea of doing an LS9 conversion?? Same cost as a HEMI.. That'd be my motor of choice if I was to do a swap..
Old 08-24-2010, 06:47 AM
ARinmyJK's Avatar
Thumbs up
Very cool like everything else I've seen in your shop. Thanks for the schooling on hemi swaps in general and the challenges of the 6 sp w/ the hemi. Definantly reinforces the idea of going S/C instead
Old 08-24-2010, 01:22 PM
Sponsoring Vendor
Old 08-24-2010, 01:23 PM
Sponsoring Vendor
Old 08-24-2010, 01:24 PM
Sponsoring Vendor
Old 08-24-2010, 01:44 PM
cuongdyna's Avatar
Have you come up with a resolution over the heating issue?
Old 08-24-2010, 01:57 PM
Sponsoring Vendor
Quick Reply: Da Sha Vu 5.7L VVT @ SLC
