Custom modular JK hardtop
#232
- Fiberglass Jeep-tub trailer kit
- Fiberglass military replica trailer kit
Available at: Jeep Trailers,Tent Trailers, 4x4 Trailers by Dinoot Jeep Trailers
- Safari Cab hardtop for LJ and TJ
- Exogate spare tire carrier/tailgate reinforcement for LJ and TJ
- Secure trunk box for the LJ/JK/CJ-8
Available at: GR8TOPS | Jeep half hardtops expert
- Heavy-duty JK tailgate hinges
- JK tailgate hinge-mounted Hi-Lift carrier
- JK tailgate hinge-mounted CB antenna mount
- Spare mount jerry can carrier for all Jeeps
- Side-mount jerry can carrier for the LJ and TJ
- Spare mounted Excursion Cargo Rack for all Jeeps
Available at: Most of these have gone through manufacturing, and one of the Jeep catalogs has signed up for them, so they should be for sale in the catalog soon (about half of these items have already been shipped to the catalog company's warehouse). It's likely that other outlets will carry these items as well. Most of these will also be for sale by the manufacturer at the Easter Jeep Safari vendor Expo. I've also got several other designs in process with the company doing these, but they're not things I've posted or can talk about yet.
- "Molle Bars" roll-bar Molle sleeves
Available at: Availability soon. I'll let people know where as soon as they go on sale.
Of the designs in this thread, the most likely to get to production first would be the JK half-door upper slider windows, although that's not certain yet. Hopefully a decision will be made on that within the next week or so.
#235
My plans are much less challenging to implement than ones shown in the preliminary CAD drawings that Strike Force Zebra posted several years ago. There's no doubt that the design I'm working on can be successfully executed. I'm just waiting for a price quote on the slider window from a second RV window company, once I've got that a go-ahead decision can be made.
#236
#237
There really isn't a "universal" RV window that will fit in Jeep uppers, but the slider I'm planning could probably be retrofit into Bestop soft uppers, assuming they're as strong as the TJ ones I've got. Maybe when I get to that point you can measure your Bestop uppers so we can see if the sliders can be installed in them.
#238
A few more concept drawings...an Overland configuration of the JK Safari Cab - this one has side cargo hatches, and it's using the integrated roof rack support for a cargo basket and off-road lights.
With a roof top tent/awning.
The unedited original photo for comparison:
#239
Someone asked me if it would be possible to make a panel van version of the Safari Cab. It would be fairly easy to do with the Safari Cab parts - I'd mold new longer side panels that extended to fill the rear door window area, and I'd make filler panels for lower half of the rear door openings - they'd be fairly easy to make in fiberglass.
Here's another version, this one's got two cargo compartments in the side:
Or, the entire side panel could be made to swing up (this is drawn on a JK8, so there's no rear door fillers/door gap):
BTW here's what a panel van version of my LJ Safari Cab looks like. This isn't a concept drawing, it's an actual photo of a panel version:
#240
For the first prototype Safari Cab, I'll be installing a ZJ Cherokee roof rack. The Safari Cab is designed with tie-ins to the sport bars for the roof rack, so weight on the roof rack is borne by the sport bars, not by the fiberglass hardtop. I needed to check the dimensions for the tie-ins, so I picked up a ZJ rack at the U-Pull junkyard yesterday. Here's the rack setting on the JKU for a quick fit test:
The ZJ rack is just about the right width to clear the Alpine windows, which wrap over onto the roof. These next photos of the roof model show the Alpine windows. The rack will also span any sunroofs that might be installed. The ZJ rack channels are very easily cut to length; I won't decide until I fit the rack on the final Safari Cab roof if I'll leave it stock length or shorten it.
The ZJ rack isn't the only one that could be installed on the Safari Cab and I'm sure some people would want other racks, but I chose it for the prototype hardtop several reasons - it's a factory Jeep rack, so nobody's going to say "Hey isn't that an Explorer rack on your Jeep?". It's a good size for the Safari Cab as I've already described; it's got lots of aftermarket support, so pretty much anything you'd want to mount up there you can get a ready-to-use mounting accessory for it, and finally it's very plentiful and inexpensive since so many ZJ's are at the end of their lives.
With the proper mounting accessories, the ZJ rack is plenty strong enough for anything you'd want to carry up there. I mount my roof top tent on the LJ Safari Cab with no problems (it's got the XJ version of the rack):
On most off-road trips, I carry a rack basket up there with an extra spare, the Hi-Lift, and often extra luggage:
