Crash's Carnage- The Death of the Tonka?
Old 12-10-2009, 09:41 AM
  #641
LRBolt's Avatar
Originally Posted by AlmightyCrash
Exhaust experts...
Are there any drawbacks to the exhaust stopping short of the rear axle?
Or does it need to come out from under the tub?
I don't think it will pass state inspection that way. Might want to check with a shop that does state inspections. If I remember right, it has to end past the axle or come out of the side of the body, behind the passenger compartment, but it's been a while since I've read up on it.
LRBolt is offline
Old 12-10-2009, 09:52 AM
  #642
SFD1248's Avatar
Originally Posted by bigbluejk
Crash... did you ever do anything to your cooling system after that trip to Barnwell where you ripped off your snorkle? Cause I swear there was antifreeze steaming out that day. It sure smelled like it. I was just wondering if maybe you have been having a cooling system issue for a while now?
Russ, I was thinking the same thing. But if that was the case he would have had issuses before the big swim. Hell that was back in March. With the heat of the summer things IMO would have popped up before now. Just my
SFD1248 is offline
Old 12-10-2009, 10:17 AM
  #643
northernjosh's Avatar
[/QUOTE]
good job, looks clean.
northernjosh is offline
Old 12-10-2009, 10:41 AM
  #644
AlmightyCrash's Avatar
Drew and Russell,
Cooling system was repaired under warranty following the Barnwell run.
AlmightyCrash is offline
Old 12-10-2009, 03:12 PM
  #645
Well, hell.
Finished exhaust.
Replaced idler pulley.
Installed driver seat.
Went to shift, shifter won't budge.
Shifter finally slides back and forth, but no vehicle movement. I step on the gas and it lurches a little. Then again. Transmission not catching at all.
Decide to try to drive a block.
It dies on a bridge In the valley of a 2 lane rd in an area with no lights. .
All dash lights on. Every last one.
Pushed it mostly off of the road past the bridge. All uphill.
On foot now. Not one of these jerks will stop to give me a lift. Ugh.
Jeep dead again.
Advice?
Old 12-10-2009, 05:50 PM
  #646
joeybear's Avatar
Comfy shoes
I'd love to buy you a beer for all you've been through with Tonka. You've almost got it pegged, then something else happens.
joeybear is offline
Old 12-11-2009, 12:21 AM
  #647
brent_f70's Avatar
Tonka died on the Bridge because she was pissed you took the easy way across!!
brent_f70 is offline
Old 12-11-2009, 12:52 AM
  #648
guybergeron's Avatar
im the first to lough about that one.
guybergeron is offline
Old 12-11-2009, 02:18 AM
  #649
JeepPilot88's Avatar
Man you are not having such good luck. You have way more patience than me, I would have torched that thing
JeepPilot88 is offline
Old 12-11-2009, 04:48 AM
  #650
6DoF's Avatar
did you flush the tranny fluid? or at least check it after sinking???
6DoF is offline
Quick Reply: Crash's Carnage- The Death of the Tonka?
