Crash's Carnage- The Death of the Tonka?
#165
Ok. After hooking up the battery, here are my most obvious issues.
Relays K1, K5, K10 click repeatedly without stopping.
Butterfly on intake valve slightly opens and closes.
Hazards still flash.
This is all while the key is off
Engine still doesn't start.
Dash shows me in all gears.
#166
#167
The JK does some wierd stuff from not having grounds... Maybe checking all the ground wires would be a good idea. The little wires on the inside of the tub on the drivers side by where your left foot sits are a bunch of ground wires for the dash. If those are disconected the radio comes on and the wipers come on and stuff starts dinging... all with the key off. I dunno if that helps at all, but maybe it is just a crappy ground somewhere?
#168
#169
pull and test your starter, mud/sand is probably in it stopping the gear from comming out and engaging on the flywheel, I think it is called you bedex. After we sunk my buddies chev he couldnt start his truck when we took the starter out the opening where the gear is was completely packed.
