Crash's Carnage- The Death of the Tonka?
Old 11-10-2009, 06:00 AM
  #161
bigbluejk's Avatar
g'luck
bigbluejk is offline
Old 11-10-2009, 06:12 AM
  #162
guruman's Avatar
Good luck Crash. Let us know how it's going.
guruman is offline
Old 11-10-2009, 06:37 AM
  #163
LRBolt's Avatar
Lots of good luck, Crash!!!
LRBolt is offline
Old 11-10-2009, 06:41 AM
  #164
chrisfetz's Avatar
Best of luck Crash!
chrisfetz is offline
Old 11-10-2009, 07:05 AM
  #165
AlmightyCrash's Avatar
Ok. After hooking up the battery, here are my most obvious issues.
Relays K1, K5, K10 click repeatedly without stopping.
Butterfly on intake valve slightly opens and closes.
Hazards still flash.
This is all while the key is off
Engine still doesn't start.
Dash shows me in all gears.
AlmightyCrash is offline
Old 11-10-2009, 07:30 AM
  #166
el_campede's Avatar
Crash, you have shorts all over the place. I bet every connection has some sand or corrosion now connecting everything together. That is going to be a nightmare to decipher. Good Luck! Don't drink to many s while trying to figure this one out.
el_campede is offline
Old 11-10-2009, 07:38 AM
  #167
bigbluejk's Avatar
The JK does some wierd stuff from not having grounds... Maybe checking all the ground wires would be a good idea. The little wires on the inside of the tub on the drivers side by where your left foot sits are a bunch of ground wires for the dash. If those are disconected the radio comes on and the wipers come on and stuff starts dinging... all with the key off. I dunno if that helps at all, but maybe it is just a crappy ground somewhere?
  #168
stlfan06's Avatar
What exactly is it doing when you turn the key to start it?
stlfan06 is offline
Old 11-10-2009, 11:22 AM
  #169
all the dash lights come on, and it dings to tell you the key is on.
thats it.
Old 11-10-2009, 11:47 AM
  #170
john smack's Avatar
pull and test your starter, mud/sand is probably in it stopping the gear from comming out and engaging on the flywheel, I think it is called you bedex. After we sunk my buddies chev he couldnt start his truck when we took the starter out the opening where the gear is was completely packed.
john smack is offline
Quick Reply: Crash's Carnage- The Death of the Tonka?
