convert to 5x5.5
Old 01-07-2009, 10:47 AM
Piginajeep's Avatar
I love the attitude..
Call Solid or ask Currie if they can drill JK rotors out.
Old 01-07-2009, 12:16 PM
Littlejon's Avatar
Originally Posted by w.wood jeepster
So back on topic, anyone know where I can get JK rotors with a 5x5.5 bolt pattern.
You can take them to any machine shop and they can do it for you. Also depending on who makes the axle some of them a a little wider and if this is the case you would be better off running a spacer on the rear that has the conversion to 5x5.5 from someone like Spidertrax.
Old 01-07-2009, 12:32 PM
mc4x4's Avatar
what about the dynatrac replacement 44 housing
Old 01-07-2009, 12:37 PM
Piginajeep's Avatar
He'll still have his 5x5 shafts then..
I used spydtrak wheel adapters on my new JK. I can even tell they stick out further than the front.
Old 01-07-2009, 01:04 PM
w.wood jeepster's Avatar
Dynatrac 44 housing is unfortunatly 3 mos away from production.
Old 01-07-2009, 01:08 PM
I calleds solid and they said just to drill out the current rotors. I think that's what I will do. My goal is not to be wider in the rear than the front. Currie claims that it is stock width but I think it will end up being wider than stock. If that's the case, I'll probably go with adapters,.
Old 01-07-2009, 01:11 PM
casaintsfan's Avatar
it's only money?
hey w.wood jeepster
send me a front and rear w/ 5:38's front & rear arb lockers, it's only your money
thanks alot, appreciate it
Old 01-07-2009, 01:25 PM
Former Vendor
David @ Currie Ent.'s Avatar
Our Rock Jock 60 front end is wider than stock, 68 3/4" wide. When you buy the front end let me know and I'll take care of re-drilling the rotors.
Old 01-07-2009, 01:34 PM
Just curious, how much wider than stock?
Pm sent also.
Old 01-07-2009, 02:30 PM
mc4x4's Avatar
i think the stock is 65
Quick Reply: convert to 5x5.5
