Constructed an "instatrunk"
It was actually really simple to make. While its almost impossible to theft-proof a soft top, unless someone climbs in, and pulls the seat back, it's safe. I used a shelf that measures about 63 inches across. And has different notches and widths due to the tailgate and roll bars. I covered it with felt and staple gunned it to the bottom of the shelving unit. I added a support beam underneath the shelf directly in the center to keep it from bending. If you have a table saw or a jig saw, you can construct it easily.
The three bolts shown in the picture simply go into the holes that the hardtop would be bolted into.
Is that a 4dr Sahara in all white I see in the garage too? "you are making me JEALOUS "
Yeah that's the all white sahara 4 door. Unfortunately I do not have access to it because it is my mom's but it is a hell of a wrangler.
I like the idea of spraying it with Berliner. It will give it a rugged look
I did something very similar to my '92 XJ some 10 years ago and have thought about doing it with my JK. I believe you've added a check mark to the do it column... Nice work and welcome!
