Comp cut and 2 door stretch
Old 01-06-2012, 03:38 PM
vfireman309's Avatar
Originally Posted by wells
Are you making your own corners?
Yeah I'm going to build my own. I really didn't want to spend the money on a set of corners that I have to chop up they are pretty expensive.
Old 01-07-2012, 02:37 PM
Got the fuel fill moved forward and driver side cut.
ID:	260763   Click image for larger version
Old 01-07-2012, 03:08 PM
07JKRUBI's Avatar
x 2 on the shot from the rear. It looks like you made you cut the same way I want to. I will be doing mine in the next couple of months so I will be keeping an eye on this build. Looks good so far....
Old 01-07-2012, 03:11 PM
Here is a few from the rear. I have to get the corners built for it yet so everything will be covered.
Old 01-07-2012, 03:25 PM
07JKRUBI's Avatar
This is exactly the way I want to cut mine. I think it looks so much better with a staight cut that follows the tail gate line then the diaginal cut.
Old 01-07-2012, 04:51 PM
JK UNLIMITED's Avatar
I love what you are doing...keep posting it is looking good...can't wait to see it done
Old 01-23-2012, 02:34 PM
Got some updates my kit came on today. Got all the control arm brackets welded on and the rear axle under the jeep. We have to relocate a crossmember that sits above the axle since I will only be running around 3.5 to 4 inches of lift.
ID:	268995   Click image for larger version
Also got my front coilovers in.
Old 01-23-2012, 02:45 PM
CALIJK's Avatar
Looks great - what size and brand of coilover are you going with?
Old 01-23-2012, 03:14 PM
I went with the Rock Krawler RRD 2.625 12" coilovers. They are very beefy and look great.
Quick Reply: Comp cut and 2 door stretch
