Coil Over System,... Can Anyone Explain the Benefits?
#31
#32
Exactally. If I did away with my springs and shocks the only thing left is the track bar brackets and longer sway bar links. I purchased the control arms separately' Can I get the lift from the coil overs? I mean, the lift I got came from the springs. Sorry if I'm still not understanding.
#33
Yes. The coil overs replace the springs and shocks that you currently have. They call it a coil over because the coil spring is over/around the shock. Your current shock and spring mounts will be cut off and replaced with the mounts needed for the coil overs. Here is a thread with some install pics.
Project-JK Gets Off Road Evolution EVO-flex - Part 1: Front Coil
#35
Oh, I see. (no pun intended) Control arms it is then.
#36
#37
4 inches would be all I need right now. I have 35's at the moment and am thinking about going to 37's when these wear out. I was wanting to get this kit then get the control arms from Clayton. I guess I just have to save a little bit longer so it can be done all at once. Maybe I will win them in the 12 days of Christmas give away.
#38
JK-Forum Founder
OK.. after reading this through.. Whats the best set up to run the Evo. I was thinking the Terraflex long arm upgrade and then get brakelines, trac bars... etc...
I have the 4.5" clayton lift but if I was going with the Evo Kit wouldn't I want to upgrade to long arms to take full advantage of the kit?
