Coil over system
#72
JK-Forum Founder
well, you've set the bar and if they can deliver half as much as you seem to be promising, i'll be eager to see some hot new original stuff that's never been done before. sure hope they can put their money where your mouth is
#73
JK-Forum Founder
yes. it will work with just about any long or short arm kit. in fact, prior to the fulltraction long arms i am running now, i was running this setup on teraflex short arms.
#76
Hey WOL and Trail Bud, I heard rumors that the evo setup makes a lot of noise. I didn't notice this at Odessa but wondered how it is on and off road? I guess the concern is all the bushings squeaking (maybe in the rear lever setup)?
#77
JK-Forum Founder
don't know where you've been hearing these "rumors" but, you saw our jk's in action and i would hope that would be proof enough for you discount them as being just that, "rumors". sure, i have seen/heard of a case where another shop totally screwed the install and that caused squeaking and an eventual break but, if properly installed and maintained, the evo lever will remain quite. to be honest, the same would apply to most aftermarket suspension componets regardless of who it's made by.
#79
#80
Passenger front is stuffed as is driver rear. Driver front still has traction at full flex same for passenger rear. FYI - it's 6 ft. from the bottom of the tire to the bottom of the fender flare.
